saiT's avatar
saiT
Readynas Ultra 2 RNDU2000 - fails to power up - how to recover
My old ReadyNas Ultra 2 with two 1 TB HDD configured with RAID 1 fails to power up.
PSU seems to be ok, but I have tested a brand new PSU as well and "no sign of life".
Nothing seems to work, the fan is not running and no led, no nothing...
I have given up the NAS as such but I want to recover my files. Tested with some software on my PC (windows) and it seems like the disks are at least on ok on "high level" - It could be seen that they are configured as RAID 1 and that there seem to be about 500 GB of data, but i cant see or fetch any files.
What are the options to recover data?
Can I buy a new Netgear NAS (not preferred), will I then be able to retrieve the data, which model(s) might be compatible?
Is there any program that I can install on my PC to read the files? (I have tried Diskinternals LinuxReader)
Would it help to install Linux? Which version in that case?
    • saiT's avatar
      saiT
      Sorry to say - I have not converted the NAS to run on OS 6.
      • StephenB's avatar
        Actually that's a good thing - there are more tools to access the ext file system OS 4.2 uses than there are for the btrfs file system used in OS 6.
ProSupport for Business
