Lham
Aug 19, 2015Aspirant
readynas ultra 4 failed: volume not found. #25615160
Hi, My Ultra 4 failed after rebooting after a RAID scub and not the C: drive cannot be found. My case ID is #25615160 Can anyone advise how i can mount the drives so i can retrieve the data? ...
Aug 19, 2015Guru - Experienced User
Depending on the problem, you might not be able to mount the disks. Can you provide more information on what support is telling you?
- mdgm-ntgrAug 19, 2015NETGEAR Employee Retired
Looking at the logs it looks like two disks have dropped out of one of the RAID-5 layers.
Do you have a backup?
