Mlidman
Apr 05, 2017Aspirant
ReadyNas Ultra 4 RNDU4000 - Cannot change settings, shares not working after restart.
Could not registrer it. It's showing as "already registered" Hi,
My Ready Nas has been serving for a couple of years day and night whithout any issues. Suddenly I started to get error messa...
- Apr 05, 2017
Your 4GB root volume was filled with a 2.9GB log file for the Skifta add-on. That add-on hasn't worked for a long time now as the service has been shutdown.
The services file was corrupt so I put the default one back on. So services that were enabled may be disabled and vice versa. To use your add-ons you'll need to install them over the top of themselves.I have removed the Skifta add-on and have rebooted the system.
Apr 05, 2017Guru - Experienced User
Mlidman wrote:
Serial# xxxxxxxxx (Could not registrer - "already registred")
Did you register it? Or is the unit used?
EDIT- mdgm already answered this (our posts crossed).
Mlidman wrote:
...I can log in to the management console if I restart th RN but cannot do any changes. And the shares are no longer reachable. ...
I know that my box is quite old but I wonder if it is still possible for the support to access my box.
There are multiple possibilities, but my guess is that you have a full OS partition.
If you are the original purchaser, you can use paid support for this (my.netgear.com). Ask about per-incident support.
Mlidman wrote:
... ist there a way of removing the disks and plug into like a dumb USB disk chassi to save the data. Put the RN back to factory Default and put the disks back again.
As mdgm says, this procedure wouldn't work.
At this point you'd need ssh access (and some knowledge of linux). Before the lockup you could have created backup jobs that were tied to the backup button on the NAS which would have done backup up the NAS to an external USB drive. But if settings aren't saved, you can't do that now (and it's possible that the backups would fail anyway if there is no room in the OS partition).
