buriedpast's avatar
Dec 02, 2019
ReadyNAS Ultra 6 - ERR: Could not properly extract
I am attempting to resolve a problem with a friends Ultra 6 that has me at my wit's end.  In short, an attempt had been made to upgrade this legacy unit to OS6 and during the process, the update fail...
  • buriedpast's avatar
    buriedpast
    Dec 07, 2019
    The NAS was not caught in an OS update.
    After numerous efforts way too involved to mention here (I barely understood what I was doing since I'm not a Linux guy), it turned out that the problem was one of the simplest possible.  Turned out that the 1GB factory memory stick was defective.  When I attempted to run a Memory Test from the Boot Menu, the test progressed for 8 seconds and then stalled.
    Swapped  memory between the problem machine and a good Ultra 6 and the memory test on the bad machine ran to 100% while the good machine stalled at 8 seconds.  With the unit now running with good memory, all previous failed efforts (manual OS upload and factory reset) progressed through completion without encountering the "could not properly extract" error.
    I have to say I'm very surprised the system would boot and run with faulty memory, which is why I didn't consider a memory test early on in this process.  Needless to say, a memory test will be the first thing in my arsenal if any problems are encountered on a machine from this point forward.
    Thanks to those who contributed to the thread and via PM.  I definitely learned a lot while debugging this system.
ProSupport for Business
