Charybdes
Nov 03, 2017Aspirant
ReadyNAS Ultra 6 - Volume expansion problem
Hi, I added a new disk in my ReadyNAS Ultra 6 to expand the volume. Volume expansion started, but the the whole NAS froze (not even responding to ping) and I had to force a reboot (pressing power...
- Nov 04, 2017
What was the initial size of your volume and what size would it be now if the expansion completed? It sounds like you have run into one of the expansion limits of the file system used by OS4.2.x: The limits are explained in item 3 of this article: ReadyNAS-Volume-Expansion. Your Ultra6 can run OS6, though unofficially. So if you end up needing to factory default to get around your problem, you may want to consider going to OS6. It has no similar limits.
Charybdes
I found this in the expansion.log file :
[2017/11/03 15:01:28 2088] LINE 4249: exec command: resize2fs -pf /dev/c/c
resize2fs 1.42.8 (20-Jun-2013)
resize2fs: Not enough reserved gdt blocks for resizing
Filesystem at /dev/c/c is mounted on /c; on-line resizing required
old_desc_blocks = 1046, new_desc_blocks = 1139
[2017/11/03 15:01:28 2088] Expand second phase error 10: resize2fs, err=0x100
- SandsharkNov 04, 2017Sensei
- CharybdesNov 04, 2017Aspirant
Hi,
Thank you for your answer.
It seems you are right since since the initial size of the volume was 3Tb (2x3Tb disks - redundant) and my problem occured when I tried to add the 5th disk (for an expected 12Tb volume).
And thank you also for the OS6 advise.
Best Regards
