ahogeweg
Mar 15, 2020Tutor
ReadyNAS Ultra 6 missing model name and serial number, corrupt VPD
My ReadyNAS Ultra 6 was running stable for many years, also after upgrading to OS6. But at some point it wouldn't boot anymore and only showed 'ReadyNAS' on the display . This text is shown as soons ...
- Mar 15, 2020
Hi!
Your NAS should reboot at this time and will have the correct SN, Hope we were able to help!
Regards
Marc_V
Mar 15, 2020NETGEAR Employee Retired
Hi!
Regards
- ahogewegMar 15, 2020Tutor
Thanks you so much. The NAS now has a model name and serial again.
Model is now ReadyNAS Ultra 6 Pro, instread of an ReadyNAS Ultra 6. But I can live with that :-)
- AndreiVJul 25, 2022Aspirant
So, what was the solution?
Did Marc_V created new VPD file for you?
I run into the same problem.
Interesting thing that all my attempts to create recovery USB using recovery tool failed.
I mean the tool said it created, but it didn't work.
And manual procedure worked!!!
Need to start cmd in Windows as admin though.
- ahogewegJul 25, 2022Tutor
Yes, there was remote assistance provided by NetGear staff to add the missing information.
I was contacted by NetGear and had to put NAS in remote assistance mode and make sure it is exposed to the internet (port forwarding in firewall). Before this I had many attemps myself, which all failed.
