thekidbass
Nov 06, 2022Tutor
Readynas Ultra 6 (RNDU6000) After Memory Test and rebooted Error " No Disks Detected"
Hopefully this time it's posted on the Readynas community webstie.I have an Readynas Ullra 6 (RDNU6000) with 6x3TB installed. RAIDiator ver 4.2.31. Flex-RAID level-0. After viewing post from Mook1 "...
- Dec 30, 2022
thekidbass wrote:
When this Ultra wipe out all the media I had in it (18TB), I already had it all backed up on raw HDs stored in my closet.
It is of course best practice to have a backup of the data even with X-RAID, since RAID redundancy isn't enough to keep it safe.
When you do have backup(s), the downsides of RAID-0 are just an inconvenience, since you can recreate the volume and restore the data from the backup if it fails. Time-consuming, but not a disaster.
Dec 29, 2022Guru - Experienced User
thekidbass wrote:
But aside from that, while it was originally resyncing, the front display also showed "no network link". Is that because of the failed HD while it was resyncing or is it because of another issue? Never had a problem with the ethernet ports. Any thoughts, ideas or suggestions would be appreciated.
Likely another issue. You could try powering up diskless, and see if RAIDar can find it.
thekidbass
Dec 29, 2022Tutor
I'll try that now. Thank you. I'll post an update.
- SandsharkDec 29, 2022Sensei
Be sure to try both ports, and also try swapping connectors on the router/switch and the cable.
- thekidbassDec 29, 2022Tutor
I'll try that now. Thank you. Will post an updated.
I connected the ethernet cable to the other port and rebooted. It did successfully aquire a IP address. After receiving the replacement failed Hard drive later this afternoon, after formating the drives in the RAID I select, I want to upgrade to OS6, following Stephen B's link on another post I saved. Thank you Sandshark and Stephen B for you assistance and expertise.
