eirik75
Sep 23, 2021Aspirant
ReadyNAS Ultra 6 stuck at "ReadyNAS" on booting
The powersupply to the unit stopped working after a power outage. Opened the case and plugged in Corsair RM550 to the motherboard and the disks. The unit powers up, but the USB and backup status LED...
Sep 30, 2021Guru - Experienced User
Opened the case and plugged in Corsair RM550 to the motherboard and the disks. The unit powers up, but the USB and backup status LED is constantly green and the status display screen shows "ReadyNAS".
Try this again with the disks removed, and see if it still says ReadyNAS (normally it would say "no disks").
If it continues to say ReadyNAS then something is off with the 12 volt output of the supply.
