kaspar
Aug 20, 2017Aspirant
ReadyNas Ultra bricked after failed ubuntu installation
Against all advice I decided to install Ubuntu 14.04 on my ReadyNas Ultra 2. After an initial struggle, the installation was complete and everything was working fine. That is until I decided to upgra...
- Aug 28, 2017
I've sent you a PM.
kaspar
Aug 28, 2017Aspirant
Anyone?
- SandsharkAug 28, 2017Sensei
The ReadyNAS is quite particular about the USB flash drives it supports for USB recovery. The only advice I can give is to try other devices -- the older the better.
But the unit serial number and possibly other things important to run the Netgear software are also in flash. So there may be no recovery.
- mdgm-ntgrAug 28, 2017NETGEAR Employee Retired
I've sent you a PM.
