sebcbien31
Feb 13, 2021Aspirant
readynas ultra6 fan speed
Hello, Got a readynas Ultra 6000, the system temprature is pretty high (81~82°C) and fan speed is low even when setting the speed to "Cool" 712rpm How can I increase the fan speed ? I chan...
sebcbien31
thanks for replying !
My configuration file looks like this :
chip "coretemp-isa-0000"
label temp2 "CPU"
compute temp2 @%35, @%35
ignore temp3
chip "it8721-isa-*"
ignore in0
label in0 "V+12"
compute in0 @*4, @/4
set in0_min 10.8
set in0_max 13.2
label in1 "V5_0"
compute in1 @*1.68, @/1.68
set in1_min 4.7
set in1_max 5.3
label in2 "V3_3"
compute in2 @*1.649, @/1.649
set in2_min 3.135
set in2_max 3.465
ignore in3
label in4 "V1_2"
set in4_min 1
set in4_max 1.3
ignore in4
label in5 "V1_8"
set in5_min 1.5
set in5_max 2.1
label in6 "V-12"
compute in6 @*19-50.4, (@+50.4)/19
set in6_min -13.2
set in6_max -10.8
set in7_min 3.135
set in7_max 3.465
ignore fan1
ignore fan3
label fan2 "System"
set fan2_min 400
ignore temp1
label temp2 "System"
set temp2_min 1
set temp2_max 82
ignore temp3
ignore intrusion0
Should I replace mine with the one you provided and restart readynasd ?
systemctl status readynasd
sebcbien31
I tried...
does not complain anymore with hi temperature but it remains weird... basically it is weirder than before. So, I reverted the changeo
- SandsharkFeb 14, 2021Sensei
Actually changing it wasn't what I had in mind as the first step, but it is interesting that yours isn't the same as the one in V6.9.6, which is where I got the one I posted. I was maining interested in checking that the temperature is being calculated right. So, what about the questions I asked? And in what way did the NAS behave "weird" when you swapped fan2 and fan3?
- sebcbien31Feb 14, 2021AspirantHello
When I replaced the configuration file with the one you provided, fan is not monitored anymore. (See picture attached to my previous post).
Regarding the temp pre-upgrade : I do not have any idea, I bought this NAS already upgraded to 6.10.4 on ebay- SandsharkFeb 14, 2021Sensei
OK, so it is new to you and you don't know if the fan ever worked right, correct? What about the air blowing out the unit? Does it seem to be as warm as the reported system temperature? And do the temperatures start up at room temp if the unit has been off for a while, or does either show too high or low?
Also, let's see exactly what the fan settiongs are. Enter this sequence of commands and post the responses:
#cd /sys/devices/platform/it87.2576/hwmon/hwmon1 #cat pwm1_enable pwm2_enable pwm3_enable #cat pwm1 pwm2 pwm3
Note that the red is what I think it should be based on the configuration file and what my other NAS do. If that's not the right directory, see if there is one similarly named. Or do a find -name pwm1 to find the right spot. Based on your config file, I expect them to be:
cat pwm1_enable pwm2_enable pwm3_enable0
3
0
cat pwm1 pwm2 pwm3128
(something <50)
128
But don't just go trying to change them, there's more to it than that. This is just checking the starting point.
