dabrain22
Nov 15, 2016Aspirant
ReadyNas Ultra6 stuck on boot
I was getting disk warning messages i used the webui to restart the device and flagged to do a volume scan. The system is rebooting but just the ReadNas logo appears on the front of the device. No % ...
- Nov 16, 2016
First try to boot into boot menu and select Skip FSCK (or volume check, something like that, I can't remember exact entry) to see if system can boot without being stuck.
If you have backup, degrade RAID is not as scary, otherwise, please proceed with extreme caution, don't write data to degrade array before you have full backup.
If you have desktop PC or laptop with eSATA port + eSATA enclousers, you can try to power off NAS and take out disk 1 to PC/laptop to test it or clone it to a new disk(Linux Live CD or USB is very useful to clone disk). (Be very carefuly not to write anything to the disk). If PC/laptop can't bring up disk 1 either, then you may have to take risk and boot up NAS with disk 2~6 if you don't want to send the disk to data recovery service company. If by any chance, you are running OS 6 on Ultra 6 (Official support for Ultra 6 was OS 4), you can select volume read only mode from boot menu to eliminate chance of data loss should any other disk is failing.
dabrain22
Nov 16, 2016Aspirant
Well before I rebooted i got between 10-20 timeout messages for disk 1. Can i just remove disk 1 and boot the NAS normally? My raid volume will start degraded? x-raid 2. 6 disks. single redundancy.
c3po
Nov 16, 2016NETGEAR Expert
- dabrain22Nov 17, 2016Aspirant
I removed the first drive tray from the unit and the NAS boots in degraded mode drive 1 has been reinserted and fails smart test.
I always used seagate and was moving towards seagate NAS 4tb series but now im thinking HGST MegaScale DC 4000.B HMS5C4040ALE640 (0F19847) 4TB Coolspin 64MB drives are better i googled and a test was done and only .15% drives failed compared to close to 2% for the seagate drives.
What drives are you guys using?
- StephenBNov 17, 2016Guru - Experienced User
Personally I use WDC Reds, though folks using Seagate IronWolf drives here have been happy with them. Some of the larger drives now are using alternative mounting slot positions that won't line up with your disk tray - so check on that before you purchase.
HGST has been part of WDC for a while, and I think they have had some impact on other WDC designs (the WD80EFRX being helium filled for instance).
