snowridde
Apr 08, 2015Aspirant
ReadyNas unresponsive after RAIDiator and Add-on upgrades
Hello, I own a Readynas Pro Business RNDP6350. Two days ago my Readynas started experiencing some problems. Here is the sequence of events before the problems started: - The Readynas has been work...
mdgm-ntgr
Apr 28, 2015NETGEAR Employee Retired
If installing things manually you should try to get them to store as much as possible on the data volume rather than on the OS partition.
This could be achieved using a symlink or a setting change (depending on which is appropriate).
With a full OS partition it may not always be so simple to fix. Glad it was in your case.
