whip313
Aug 14, 2015Initiate
ReadyNAS Weak Encryption PCI Compliance Fails TLS1.0 & SSLv3
We have two ReadyNas 314 units that host FTPS connections available to the internet. How can we disable TLSv1.0 and SSLv3 as encryption algorithms? Even though absolutely no credit card data eve...
ray-sprong
Feb 12, 2016Aspirant
What was the resolution of the failed compliance issue? I have the same problem with the FVS318V3 running V3.0_28.
JohnRo
Feb 12, 2016NETGEAR Employee Retired
Hello ray-sprong,
Welcome to the community!
Firmware version V3.0._28 is the fix for critical vulnerability issue (SSL/TLX Authentication GAP issue). If yours is not fixed, try a firmware reflash followed by a factory reset and see if it will resolve it.
Let us know.
thanks,
