LaszloFolgerts
Feb 06, 2015Aspirant
ReadyNAS102 LMS doensn't connect to Mysqueezebox.com
Ok so yeah, pretty much what the title says. I have a ReadyNAS102 running on firmware 6.1.8 on which I have LMS version 7.8.1, to use with my Squeezebox Touch. The SBT and the RN102 are connected ...
Feb 07, 2015Guru - Experienced User
192.168.137.1 is on your local network (perhaps your router). Is that the same DNS server as your PC is using? (running command, then ipconfig /all should tell you).
If so, try connecting to www.mysqueezebox.com and make sure it connects
