MarshallKL
Apr 30, 2022Aspirant
ReadyNAS104 External USB Drive now Read Only Previously Read/Write
ReadyNAS104 Firmware: 6.10.7 For unknown reason my external Seagate Backup Plus Drive became Read Only. I have tried to change it back to Read/Write but cannot. I see this system messa...
- May 20, 2022
That worked, thanks.
I should have been able to do that on the ReadyNAS.
BTW, I have had 3 additional external drives go in the same state since.
Apr 30, 2022Guru - Experienced User
As the message says, somehow the drive wasn't properly ejected. If it is formatted in a format your PC recognizes (FAT32, NTFS, etc) then insert the drive back into the PC. The PC will offer to "repair" it. Let it do that, and when that process completes, reconnect the drive to the NAS. At that point it will be read/write.
- MarshallKLMay 20, 2022Aspirant
