dennis32
Oct 15, 2013Aspirant
ReadyNasPro Pioneer - More than 16Tb is possible?
Hi. I need just an answer. I've got a ReadyNas Pro Pioneer Edition, RAIDiator 4.2.24 Firmware RAIDiator-x86, X-Raid2. 5 x 3tbyte Hd, and 1 x 2Tbyte Hd. I've supposed to update with the last 3Tbyte...
Oct 15, 2013Guru - Experienced User
You cannot expand past 16 TiB [base 2], but if you do a factory reset with all disks in place, then you can use all the space.
If you are still under warranty (which is 5 years) then Netgear will deny support if you go off the HCL. Though it seems likely that the WDC WD40EFRX and the Seagate ST4000NV000 will be added eventually, there is still some risk on that.
You might wait a bit on the WD40EFRX and see if there is a resolution posted on this issue: viewtopic.php?f=24&t=73417&p=407846&hilit=wd40efrx#p407846
