doccy
May 02, 2018Aspirant
ReadyNASRND2000 bricked.
Hi guys.
My ReadyNASRND2000 is not powering on. Totally dead. Had a few powercuts recently - no idea if they were related.
What is my best next move - my last external back up was over ...
- May 03, 2018
OK - thanks for the help guys.
Pretty sure i have a V1 readynasduo.
Looking a bit closer - my power supply light was not on! Now confirmed it is blown.
I have orderd a replacement power supply and will try that in first instance... if there are issues then at least I know about using the linux setup to try and get data off.Cheers for the help!
Marc_V
May 02, 2018NETGEAR Employee Retired
Hi doccy
Welcome to the Community!
Upgrading to an OS 6 ReadyNAS model would be the best move here, but you need to make sure that your disks are in healthy condition and the RAID is in working condition so the migration would be successful.
Migrating to an OS 6 unit is not that simple as booting but following the steps provided on the guide then contacting Support will help you migrate your data to the OS 6 device.
Migrating to OS 6 Units (Duo and Duo V2 share the same steps on migrating data)
Here are a list of models available, I would suggest getting a RN400 series model ReadyNAS OS 6 models
Hope this helps!
Regards
