Zeroveto
Sep 24, 2016Aspirant
ReadyNASRND2000 "Main display is undefined"
I have a ReadyNAS Duo v1, win10 If i open the Raidar 4.1.1 I did not see datas, and if i try to update i got the following message: Error in evaluating table display main reference Error "Main D...
- Sep 24, 2016
This is almost certainly a browser compatibility issue - if so, then you are running old firmware.
If you have internet explorer on the PC, try using compatibility mode when you access the NAS web page. https://support.microsoft.com/en-us/help/17472/windows-internet-explorer-11-fix-site-display-problems-compatibility-view
When you regain access, update the firmware on the NAS.
Sep 24, 2016Guru - Experienced User
Zeroveto
Sep 25, 2016Aspirant
Big THX, now it works, Thank you.
- DaneASep 27, 2016NETGEAR Employee Retired
Hi Zeroveto,
I'm glad that its working fine. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
