lsh1
Apr 06, 2012Aspirant
readyns NV+ 1500 after booting, no network connection
I would appreciate help. After booting up my ReadyNas NV+, I'm not getting a network connection, i get a 1500 on the display. Here's how I got here. Previously, I tried to change the IP to static...
ReadySECURE
Apr 06, 2012Apprentice
It sounds as though there may be an issue with the network drivers
If you are currently running the latest firmware, I would suggest performing an OS reinstall.
The process will not touch data, but it will reset the NIC settings and the admin sign in for Frontview.
To perform an OS reinstall, you will need to access the boot menu, here's the guide: http://www.readynas.com/kb/faq/boot/how ... _boot_menu
