sstillwell
Apr 20, 2019Tutor
ReadyTIER with ReadyNAS Pro 6
Hi,
I've got a NAS Pro 6-bay system, currently on NASOS 6.9.5 hotfix 1 and loaded with 4 x WD RED 8 TB drives in FlexRAID RAID 5. Primary use case for the unit is as an NFS server for my VMwar...
- Apr 21, 2019
sstillwell wrote:
So...here's my putting-the-cart-before-the-horse question: Do you know of any reason this shouldn't work when adding a 512 GB RAID1 SSD tier to the existing volume?
It should work in the Pro-6 (though you do need to change to flexraid in order to use ReadyTier).
The main challenge is adapting the trays for the SSDs, and you've already found mounting brackets for that part.
ReadyTier isn't caching the metadata, so if the SSD RAID group fails you will lose the volume. Your SSDs will reach their write limits at the same time. So you might want to replace one of them about half-way through it's expected life, so you can stagger the replacements.
Sandshark
Apr 22, 2019Sensei
I'm pretty sure the Pro is only SATA2, so I wonder how much you gain with SSDs.
sstillwell
Apr 22, 2019Tutor
Well, in terms of absolute bandwidth it's obviously 3 Gbps vs 6 Gbps for SATA3...and you're not going to hit either of those limits on even a single drive over two bonded 1 Gbps network connections. The primary gain is likely to be in latency and IOPS...which is just what I want for VM backing stores. Will I gain as much as I would if the unit were SATA3? No, of course not. Will I gain worthwhile performance improvement? I am assuming so and putting my money where my assumption is. :)
- StephenBApr 22, 2019Guru - Experienced User
Yes. SATA 2 supports 300 MB/sec SSD speeds , bonded gigabit ethernet handles around 200 MB/sec. So the network is the limit.
Agreed.
