sstillwell
Apr 20, 2019Tutor
ReadyTIER with ReadyNAS Pro 6
Hi,
I've got a NAS Pro 6-bay system, currently on NASOS 6.9.5 hotfix 1 and loaded with 4 x WD RED 8 TB drives in FlexRAID RAID 5. Primary use case for the unit is as an NFS server for my VMwar...
- Apr 21, 2019
sstillwell wrote:
So...here's my putting-the-cart-before-the-horse question: Do you know of any reason this shouldn't work when adding a 512 GB RAID1 SSD tier to the existing volume?
It should work in the Pro-6 (though you do need to change to flexraid in order to use ReadyTier).
The main challenge is adapting the trays for the SSDs, and you've already found mounting brackets for that part.
ReadyTier isn't caching the metadata, so if the SSD RAID group fails you will lose the volume. Your SSDs will reach their write limits at the same time. So you might want to replace one of them about half-way through it's expected life, so you can stagger the replacements.
Apr 24, 2019Guru - Experienced User
sstillwell wrote:
Best performance seen in the graphs so far is 3500 write/1700 read IOPS.
Resync 98.65% done while I've been sitting here blathering.
I'd be interested in seeing the final iops numbers, now that the resync is completely done.
sstillwell
Apr 24, 2019Tutor
I haven't found a good real-world benchmark yet across the network, but running a synthetic fio benchmark while SSH'ed into the NAS against the local filesystem, I get some quite nice numbers.
When using queue depth 64, file test size of 10GB, random r/w I get:
12,064 IOPS read with 2.532 mS avg latency
12,057 IOPS write with 2.767 mS avg latency
I should run top in another window to see if I'm CPU bound...one moment...
Yeah, it's CPU-bound at that point. I guess I'll try running FIO from a remote machine to a share on the NAS and see what I can get.
*EDIT* Yeah, running fio on a fire-breathing Mac Pro via SMB share is not nearly as impressive. Getting ~550 IOPS read or write when unbuffered...only change in parameters is pathname and changing libaio (Linux-specific) to posixaio
For reference, I'm using the following fio parameters...
[random-read]
ioengine=libaio
iodepth=64
direct=1
invalidate=1
rw=randrw
size=10G
directory=/volume1/main/IOTest/fio-testing/data
