Radjin
Nov 26, 2017Aspirant
Recamended order for maintenance: (Scrub, Defrag, Balance, Disk Test).
I read the suggested schedule for maintenance activities but did not see a recommended order. Some activities will affect the condition that other activities correct (eg; scrubbing may affect fragme...
- Jan 20, 2018
Radjin wrote:
1. Do I lose access to teh unit while it does a disk check.
No, though performance might drop a bit.
Radjin wrote:
2. How long does a check take? I have 3 12TB disks installed.
I have 4x6TB disks (WD60EFRX) in my RN526x. The last disk check took 13 hours. It should scale linearly, so I'd expect your test to take about 20 hours.
Radjin
Jan 20, 2018Aspirant
Thanks, I couldn't find anything in the documentation as to exactly what happens.
Jan 20, 2018Guru - Experienced User
