wingzero1
Nov 23, 2022Aspirant
Recently my Readynas Ultra 6 Plus keeps rebooting randomly every 20min-1hour
So since last week my Readynas Ultra 6 Plus, keeps rebooting every 20min-1hour I hae searched the forums and found another topic about this, however it is closed and i couldn't respond in it, so t...
Sandshark
Nov 23, 2022Sensei
And there is nothing in the log showing the power off, just a new power on?
A marginal power supply might cause that, especially the +5VSB (+5V Standby), which powers the on/off circuit. That's a common issue with the older NAS models -- the power supply just doesn't last forever. But, it is replaceable with a standard SFX format PSU, though you need a 24-pin extender cable and may need one or more SATA to Molex power adapters or Molex Y cables. If you have a "spare" ATX12V supply, it can be connected externally to see if that fixes the problem before you invest in a replacement (though they aren't that expensive).
While the standard PSU is only 300W, I recommend at least a 350W replacement because the original has more 12V current capacity than a typical 300W. I've used a lot of different versions, since many have come and gone from the market, and usually go with a 400W.
If you want the easiest/cleanest replacement, there is a vendor on eBay that has some that already have the needed cabling.
- wingzero1Nov 23, 2022AspirantHey, thx for the reply.
I am going to run a mem test tonight, just to make sure there is no memory fault.
If not I will buy a replacement for the CPU.
I looked for 24pin SFX supplies and these are 2 possible candidates to buy.
If they are good...
https://www.alternate.be/Voedingen?t=8510&s=default&filter_-2=true&filter_4013=3&filter_4002=1.0&filter_4012=4&filter_4012=1&j_idt328%3Aj_idt332=Resultaten+weergeven
https://www.alternate.be/Thermaltake/Toughpower-SFX-550W-Gold-voeding/html/product/1718547#product-details-tab - wingzero1Nov 24, 2022Aspirant
So, i was running a Memory test, which was already running for 5+ hours......
no single fault found and because it has been up for 5+ hours i guess the PSU is also ok....
i noticed there was a lot of network traffick to google api
I have gdrive sync enabled, so i have now disabled it
waiting for results
I also got a weird error message on the screen, which do not appear in the logging- StephenBNov 24, 2022Guru - Experienced User
I think the error code is related to email alerts. Are you using gmail for that? If so, have you switched to using an app-specific password?
On the main issue, I am thinking a factory default is worth a try. This will destroy all your data, so you'll need to make a full backup first.
If you have a spare disk, you could try powering down, and removing all disks (labeling by slot). Then do a fresh install on the spare, and see if that behaves the same way.
Note if this is power-related, passing this test might not prove anything, as a single disk will obviously not load the PSU nearly as much as the full array. But if it fails, you will rule out the disks and software.
with disabling the gdrive app, it still happens the reboots.
so i am now doing a disk test, from the boot menu, but when that passes, I will need to look at the software....
However, since this is my only NAS and i have around 10+Tb of data, I have no disk to back this up...
factory default, will reset, reinstall and erase all data
OS reinstall will reinstall, but leaving configuration, but will leave all the data....
I am first going for the OS reinstall i think.
Since i did not chagne any settings or configuration since this problem started existing
