egwok
Mar 24, 2023Tutor
Just recently xr1000 help
My xr 1000 is just recently having this issue with my upNp can anyone tell me how to fix it ? Attached photo is my Xbox series x ip
(192.168.1.2 ) the 192.168.1. 16 i don’t know what device it is since it don’t show up on device manager . Anyway it fluxates my Xbox series X Port from 3074 to 55875 to 51332 . My NAT type is open most times .
There is a wifi button on top of the router that you can press for 5 seconds then release that will turn OFF the wifi radios. Pressing this again for 5 seconds then release will turn them back ON.
You need to find out what device is connected to your router that's using .16.
How is the xbox connected? Wired is preferred.
I'd set up a IP address reservation as well for the xbox.
Start by disabling WiFi radios on the router to see if the .16 device disappears.
- egwokTutorI’m wired on Xbox and I’ll give it a try . And I already have the Xbox ip reserved . But I’m gonna try the WiFi thing when I looked at my manage devices I seen a lot WiFi devices connected too many to all be mine ? Could I been hacked by hacker? I’d so how can I get the hacker off my router? Factory reset will get the hacker off?
- Netduma-FraserNetDuma PartnerIt's unlikely to be a hacker, just a device that doesn't have a name on the Device Manager, check your devices themselves to see what their IP is and match it
