wingzero1
Nov 23, 2022Aspirant
Recently my Readynas Ultra 6 Plus keeps rebooting randomly every 20min-1hour
So since last week my Readynas Ultra 6 Plus, keeps rebooting every 20min-1hour I hae searched the forums and found another topic about this, however it is closed and i couldn't respond in it, so t...
Sandshark
Nov 23, 2022Sensei
And there is nothing in the log showing the power off, just a new power on?
A marginal power supply might cause that, especially the +5VSB (+5V Standby), which powers the on/off circuit. That's a common issue with the older NAS models -- the power supply just doesn't last forever. But, it is replaceable with a standard SFX format PSU, though you need a 24-pin extender cable and may need one or more SATA to Molex power adapters or Molex Y cables. If you have a "spare" ATX12V supply, it can be connected externally to see if that fixes the problem before you invest in a replacement (though they aren't that expensive).
While the standard PSU is only 300W, I recommend at least a 350W replacement because the original has more 12V current capacity than a typical 300W. I've used a lot of different versions, since many have come and gone from the market, and usually go with a 400W.
If you want the easiest/cleanest replacement, there is a vendor on eBay that has some that already have the needed cabling.
wingzero1
Hey, thx for the reply.
I am going to run a mem test tonight, just to make sure there is no memory fault.
If not I will buy a replacement for the CPU.
I looked for 24pin SFX supplies and these are 2 possible candidates to buy.
If they are good...
https://www.alternate.be/Voedingen?t=8510&s=default&filter_-2=true&filter_4013=3&filter_4002=1.0&filter_4012=4&filter_4012=1&j_idt328%3Aj_idt332=Resultaten+weergeven
https://www.alternate.be/Thermaltake/Toughpower-SFX-550W-Gold-voeding/html/product/1718547#product-details-tab
If they are good...
