ngpercy
Aug 23, 2014Aspirant
Recover data from inactive JBOD volume
Dear all, I'm using RN102, with one 4T HDD and one 1T HDD, running in JBOD, separate volume. I bought a new 4T, wanted to replace the 1T. I removed the old 1T HDD and replaced it with 4T. When ask...
vandermerwe
Aug 23, 2014Master
How did you remove and add these disks, was the NAS on when you removed the 1 tb and replaced it with the new 4 tb ( after you had recovered the data) ?
Do you have a backup?
If you don't have a backup, I would suggest that you do absolutely nothing else and contact support. Leave the NAS as it is and don't do anything with the disk that is not in the NAS.
