ngpercy
Aug 23, 2014Aspirant
Recover data from inactive JBOD volume
Dear all, I'm using RN102, with one 4T HDD and one 1T HDD, running in JBOD, separate volume. I bought a new 4T, wanted to replace the 1T. I removed the old 1T HDD and replaced it with 4T. When ask...
vandermerwe
Aug 24, 2014Master
Did you destroy the volume when you were asked. By removing the new 4 tb disk you effectively removed half of a volume that was spread across 2 disks. It is never advisable to create volumes like this unless you have a robust backup as 1 disk failure destroys the whole volume.
I think your data is gone, but you need to ask Netgear support. Have you logged a support request?
UPS is uninterruptible power supply.
