JoeG1701
Dec 08, 2015Aspirant
recovering after drive failure
Need some advice on what to do next. ReadyNAS in X-Raid2 with 3X 2TB Drives. After family complained that it could not access shares, I logged in as admin. Disk 1 status "Dead", Disk 2 status "Spa...
Dec 09, 2015Guru - Experienced User
What NAS do you have, and what firmware is it running? Also was disk 2 always marked as a spare?
I would try per-incident support next, I think it is likely that they can remount the volume w/o needing data recovery. Data Recovery has its own contract terms, and would be expensive if it is needed.
BTW, your understanding of XRAID2/RAID-5 is a bit off. If disk 2 was a spare, it was never part of your array. Normally with three disks, you'd see all disks as "ok".
JoeG1701
Dec 28, 2015Aspirant
Thanks for the response. Sorry I couldn't get back until now due to the holiday. It's a ReadyNAS RNDP400U with up to date firmware (just updated prior to incident). I have 3X 2TB drives and before the failure, all were Green/OK with 3.6TB of total space. When the failure occured and the NAS went into "Life Support" mode, Disk 1 was "Dead", Disk 2 was "Spare" and Disk 3 was "OK" I could access my shares and subfolders, but not the actual files.
I pulled disk 1 and replaced it with same make/model. For a while, Disk 1 and Disk 2 were "Spare", and Disk 3 was "OK". Now, all 3 disks are green/OK, but the volume is not mounted. I can't access anything right now. I'm fairly sure my data is still there, but I don't know how to re-mount the volume, and I don't want to create new volume/shares and potentially overwrite my data.
I'm going to go ahead and call support today and see if we can get to my existing data. Before I paid the per-incident price, I wanted to have a good feeling that the data was still there.
Edited to fix massive number of typos.
- JennCDec 29, 2015NETGEAR Employee Retired
Hello JoeG1701,
Welcome to the community!
I think the data is still there. But have the old disk 1 ready too, it is possible they will require data recovery service contract, but try the per incident first.
- JoeG1701Dec 30, 2015Aspirant
Thanks for your warm welcome and guidance. Went throught the support system and scheduled a date/time for them to call me to work the issue. Got confirmation through the support ticket that they would call me at my "preferred time". It's currently 2 hours past that time, and I have not heard from them yet. Is this normal?
- JennCDec 30, 2015NETGEAR Employee Retired
Hello JoeG1701,
Sorry to hear that. I'll check with the support team what happened.
