xtrips1
Nov 15, 2017Aspirant
Recovering permanently deleted files from Readynas Pro
Hello, How do you recover deleted files from a Readynas Pro? I deleted a share thinking it would do that like under Windows. I know I will lose the directory structure and the files names and e...
- Nov 15, 2017
I don't know of a good way to do this. You could try installing extundelete using ssh I guess.
Of course if there are disk writes, the ability to repair rapidly disappears.
If you had the network recycle bin enabled, you might be able to get some data back from there.
Nov 15, 2017Guru - Experienced User
