gaz8080
May 09, 2017Aspirant
Recycle Bin
Hi, Can anyone tell me how to empty the recycle bin or where I would find options for controlling the size of the recycle bin? Thanks, Gaz.
May 09, 2017Guru - Experienced User
Can you tell us what firmware the NAS is running?
gaz8080
Hi, yes it's RAIDiator 5.3.11 - I'm planning to update to 5.3.12 soon if that will make any difference.
- StephenBMay 09, 2017Guru - Experienced User
I wanted to confirm that you had a v2 (many v1 owners think they have v2's).
I don't own a v2 NAS and the software manual doesn't mention the recycle bin - so I can't help on your specific question. Hopefully someone who can will chime in.
