neonshades
Jul 13, 2016Tutor
Recycle bin on RN104
Please give me an easy answer.... and please only answer if you know (no guesses).
is there a tick box to enable the recycle bin on the RN104?
My ReadNas NV+ V2 has a tick box to enable the recycle bin but I cannot find it in the RN104 menu. Help....
Thanks,
Robert....
Hi BrianL,
Unable to follow your thread. Will not accept my login.
Nor will it send me a password update.
Robert....
Must be a cut-and-paste error on Brian's part.
You could look here: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-2-on-a-314/m-p/856712/highlight/true#M26776
and perhaps read through the posts after the highlighted thread as well. The process will require some knowledge of linux.
Though I find Snapshots to be a good alternative. With snapshots enabled, you can roll-back to older versions of the share, and if you right-click from windows on a file you can see/access previous versions. If you right-click on the folder and access previous versions, you can select deleted files and restore them. It's not exactly the same as the recycle bin, but it is similar.
