ianren
Sep 17, 2012Aspirant
Remote Access to Frontview - ReadyNAS Duo V1
Very occasionally, access to Frontview is lost which requires a reboot of the NAS in order to restore access. Access to shares both locally and through ReadyNAS Remote remain available, as does all fu...
mdgm-ntgr
Sep 17, 2012NETGEAR Employee Retired
Are you using Windows/Mac/Linux?
If using Windows download a free application called PuTTy.
If on Mac/Linux use the Terminal.
The port for SSH is port 22 though you could just SSH in via ReadyNAS Remote (think you would need the ReadyNAS Remote Firewall to be disabled to do this though). If you port forward port 22 be sure to set a strong password.
What version of RAIDiator is on the unit?
I wouldn't recommend 4.1.9 due to an ownership issue.
