fiber2
Jun 09, 2017Tutor
remote Time Machine
Hi, How would it work to use remote Time Machine? I suppose Time Machine does not simply offer the remote share in the list of possilbe locaitons. Netgear says it is possible, but I can't find an...
Jun 09, 2017Guru - Experienced User
fiber2 wrote:
Hi,
How would it work to use remote Time Machine? I suppose Time Machine does not simply offer the remote share in the list of possilbe locaitons. Netgear says it is possible, but I can't find an explanation how to accomplish that.
I have plenty of bandwidth...
I am wondering if your best option here is to join the two locations with a VPN solution.
This can be done with small enterprise VPN routers. You might also be able to set up ZeroTier to interconnect the two NAS - Sandshark might know.
A VPN would allow you to securely access the remote network, and have full access to it. If you use VPN routers, it will look like one network (transparent to the users).
fiber2
Jun 18, 2017Tutor
Yes I have tried to set up a VPN between 2 routers. However, the internet provider of at least two sites also provides the modem/router. I cannot set up a VPN on that router: it is not an available option.
That device also other services and the provider is not willing to share the necessary data to set all services up on devices that I would install. So, stuch with that provider for the moment for a few locations.
Thanks, maybe ZeroTier is a good solution at least untill I get the provider changed.
But since Netgear claims it is possible, hope to learn how to do it without ZeroTier as well.
Unless I learn more on the Netgear solution within the next days, I will try ZeroTier.
- StephenBJun 18, 2017Guru - Experienced User
fiber2 wrote:
However, the internet provider of at least two sites also provides the modem/router. I cannot set up a VPN on that router....My ISP is Verizon Fios, and they also require that you use their router (otherwise you lose their TV services). What I do is double-route - putting a Netgear router behind the Quantum one, and running VPN on other services on that. Port forwarding is a bit more complicated, but I don't forward a lot of ports anyway.
