Askii
Jan 18, 2018Tutor
Remote User on ReadyNAS duo v2
Hello, At first sry for my English, I'm German. I try to set up my Readynas duo v2 with Remote Acess. I istalled the Client on my Desktop and get it started an I created an Account. After that i...
- Jan 20, 2018
Askii wrote:
Thanks, but the Forum seems to be closed
Did you notice the part where it said
To sign up for the RNxtras team, use the link below:
Marc_V
Jan 18, 2018NETGEAR Employee Retired
Hi Askii
Welcome to the Community!
You may also want to consider changing your NAS to an OS 6 Unit, it Supports ReadyCloud and of course the latest updates.
Regards
- AskiiJan 18, 2018TutorHow can I Upgrade to OS 6 did Not found a Firmware Download
Manuel Felchner- Marc_VJan 18, 2018NETGEAR Employee Retired
Hi Askii
Sorry but StephenB is correct your unit is not upgradeable to OS6, You might just want to upgrade to a new NAS unit/model which runs on OS6.
Hello,
at first thanks for your help. I purchased OwnCloud but now i have the next Issue. If i Try to install the donloaded Addon (.bin file) my NAS shows the percent up to 100% and after that it shows me an Error Message. I really hope you can help me. The NAS has a connection to the internet, i can acess it via FTP, so i do not know where is the problem.
Thanks for help
Manuel
