davidr1
Dec 16, 2015Luminary
Remove contents of backup destination option not working
Hi, Problem occcurs on NAS 314, NAS Pro (OS6) and NAS Ultra (OS6) I have a backup I run every day of /data folder (hence all my shares). It is rsynced to a usb drive attached to the NAS to (...
davidr1
Hi BrianL,
I use linux - ubuntu 14.02.3:
rsync in linux does delete the folder contents. However, as my PC is not running all the time I need this to work on the NAS.
All nas units are running 6.4.1. Looking at monthly backups I found the same problem was occurring in at least the previous two versions.
I notice the logs sent by email say:
Successfully completed backup job pro_data_backup. -------- Backup Job Information -------- Backup Job Name: pro_data_backup Backup Job Type: Incremental Protocol: rsync Backup Source: [volume:data]/ Backup Destination: [remote:rsync]/192.168.x.x::USB_HDD_1
The backup is definitely set as a Full backup Every time, not Incremental.
Best regards,
David
davidr1
Feb 13, 2016Luminary
polite 'bump'
- BrianL2Feb 15, 2016NETGEAR Employee Retired
Hi davidr1,
Will you give 6.4.2 a try and other USB drives and see if the behavior is the same.
Kind regards,
BrianL
NETGEAR Community Team- davidr1Feb 17, 2016Luminary
Hi BrianL,
Nas314, Ultra2, Pro2 using 6.4.2
I have exhaustively tested as per your request and the problem remains. The folder is not deleted and it appears only incremental backups are taking place. If the folder was being deleted then there would not be files or folders that no longer exist still in the folder , right?I have tried:
Removeable usb drives
external hdd
Formatted to:
usb: fat32, ntfs, ext4
Test:
daily backups with comparison of before / after over on all drives and file systems.
David
- BrianL2Feb 17, 2016NETGEAR Employee Retired
Hi davidr1,
That's what it supposed to do. I will have this check and let you know what I can find.
Kind regards,
BrianL
