jmaxlow
Apr 07, 2019Aspirant
Remove inactive volumes on EDA500 expansion chassis
I have run an RN516 with three EDA500 expansion chassis for multiple years. Recently, an error where one disk in one of the expansions disconnected and then reconnected (on its own) triggered a resyn...
- Apr 11, 2019
Hi all
Just to follow up on this one for those interested.
jmaxlow was getting inactive volume error on both EDA-2 and EDA-3. The reason being that neither raid can start.
The raids cannot start because several disks in both EDAs are missing the data partition. EDA disks should have two partitions: 1 for the OS and 1 for the data. These are referenced to as partitions 1 and 3. Several disks are missing the data partition and thus the raids cannot run.=== EDA-2 === 8 176 5860522584 sdl 8 177 4194304 sdl1 8 192 5860522584 sdm 8 193 4194304 sdm1 8 195 5855803936 sdm3 8 208 5860522584 sdn 8 209 4194304 sdn1 8 224 5860522584 sdo 8 225 4194304 sdo1 8 227 5855803936 sdo3 8 240 5860522584 sdp 8 241 4194304 sdp1
=== EDA-3 === 65 0 4883770584 sdq 65 1 4194304 sdq1 65 3 4879051936 sdq3 65 16 4883770584 sdr 65 17 4194304 sdr1 65 32 4883770584 sds 65 33 4194304 sds1 65 35 4879051936 sds3 65 48 4883770584 sdt 65 49 4194304 sdt1 65 64 4883770584 sdu 65 65 4194304 sdu1 65 67 4879051936 sdu3I am a little baffled as to how this happened on so many disks. Perhaps there is a communications issue between the EDAs and the main chassis... Disks appear healthy.
Anyhow, this should be recoverable by copying over the partition table from "working" disks and thus restore the lost partitions. As long as nothing was over-written on those disks we should be good.
I recommended to reach out to NETGEAR and show them this.Cheers
jmaxlow
And now the web interface is inaccessible, with eda1's resync seemingly stuck at 14.08%. Here is my RAIDar result.
Is there an SSH command I can use to "restart" the web interface?
- StephenBApr 08, 2019Guru - Experienced User
Did you try downloading the logs from RAIDar?
- jmaxlowApr 08, 2019Aspirant
RAIDar would ask for a username and password for the log download, but would then reject them, and would do the same for the graceful Restart.
I had to do a hard restart. At that point (last night), I powered off the two troublesome expansion chassis so that FrontView would load and the resync on eda1 would continue. So now that resync is progressing. I can download the logs but they don't seem to contain any errors specific to eda2 and eda3 - no SMART errors and such. But the content on those two in the logs is not as voluminous as the content on the RN516 and eda1. Once it is finished (Wednesday?) I plan to turn eda2 and eda3 back on and try to get those logs.
Would it be helpful to post what logs I have today, or what until the resync is finished and I attempt to turn the other two chassis back on?
I am very much hoping that it's the case that the data on eda2 and eda3 is still there, and the arrays just need to be reassembled via the command line, but I pretty much have to wait until the resync on eda1 is done before chat support is willing to get more involved. I'm prepared to use Reclaime if I have to, but perhaps something simpler and faster will work.
Well, don't post a link to the full log zip file here.
Instead, send a private message (PM) to the mods ( JohnCM_S or Marc_V ) and ask them if they are willing to take a look. Hopchen might also be willing to analyze them.
- SandsharkApr 08, 2019Sensei
The existance of "eda2" with "eda2-0" and "eda3" with "eda3-0" says there is (probably only) one drive in each chassis that is out of sync. It thinks there are two volumes with the same name, which it can't resolve. And while it may seem obvious which one is the "true" volume by the amount of space used, that's not always the case.
The problem is that you really need to get past the stalled sync. I'm assuming here that top shows it's eating up all the CPU throughput and that watch cat /proc/mdstat shows no progress in the re-sync and time to go just mounting up. I've seen that before, and it often keeps other commands issued via SSH from working.
Whether something happend that drove all the volumes out of sync or if the resync of eda1 dominoed into messing up eda2 and eda3, it's hard to say. I had a similar situation as your eda1 recently with an external eSATA 5 drive chassis (works like an EDA, but is from another company) and nothing I did could save that volume. I resigned myself that it was lost, and I deleted the volume, re-created it, and restored from backup. But before I did that, I booted with it not connected but my real EDA500 connected, and it booted. Yours may as well and give you more information on which drive is the out of sync one. If you can remove that drive and re-boot, the "phantom" volume should disappear and you can then put the drive back in, format it, and then let it re-sync.
Since you have three EDA's, you may want to boot with just one, get it working, then boot with the second. Note that when you boot without it, the volume will still show up in the GUI as missing. Don't destroy that unless you plan to start over with the EDA. If you get one EDA volume working and want to keep it "safe" when working on another, do an export. Note that once re-imported (whihc happens automatically when you boot with it attached), you will need to go back in and set protocols and permissions on the shares. And this whole thing could move you to FlexRAID mode, where you could be stuck (assuming you aren't there already).
Note, too, that every time you boot with a sub-set of total drives, md0 (the OS partition) may need to sync. It doesn't take long, but it's best not to power down while it's ongoing.
