pavelh
Jun 01, 2013Aspirant
Replace disk in Readynas DUO 1
Hi, last week I had some troubles with disk in my ReadyNas DUO. Disk 1 is original Seagate Barracuda 7200.10, Device Model: ST3750640AS and it is OK (or I hope so). Two and a half year ago I added sec...
Jun 01, 2013Guru - Experienced User
You are running flexraid, and selected RAID-0. You created two volumes though (one for each drive), which keeps the two drives independent.
Maybe try removing disk 2, and rebooting the NAS. Then install disk 2 again, and see if you can create a new volume at that point.
