zigdapig
May 18, 2017Aspirant
Replace disks (FlexRAID RAID 1) with larger disks
Hi, My Readynas Ultra II is currently setup as FlexRAID (RAID 1) with 2 500 GByte disks. I now have 2 brand new 4 TB disks. What are the steps I should follow to replace both disks (while ke...
jak0lantash
May 19, 2017Mentor
zigdapig wrote:If I understand it correctly from topics I read, the FlexRAID volume will not simply (automatically) expand to the new drive size, is that correct ?
If we were talking about OS6, I could explain that this isn't correct. Unfortunately, I don't recall the Flex-RAID vertical and horizontal expansion rules on RAIDiator 4.2. The user manual doesn't help.
Maybe mdgm-ntgr could help clarify this.
Flex-RAID on OS6 (Before 6.7.0 anyway - I think there was some changes introduced in 6.7.0):
- Vertical expansion occurs when all the HDDs are upgraded. Compared to X-RAID which creates sub-arrays on the unused capacity, Flex-RAID "extends" the existing array once unused capacity is available on all members.
- Horizontal expansion occurs when there is enough new disks to create a new vdev. Compared to X-RAID adds the disks one by one into the RAID array (or layers of RAID arrays), Flex-RAID creates a new vdev and add it to the BTRFS volume (in single mode).
Flex-RAID on RAIDiator 4.2:
- Vertical expansion rules?
- Horizontal expansion rules?
It's correct that you can backup your entire volume on a USB disk but cannot restore your entire volume from a USB disk (which is reasonnable when considering that the folders on the USB disk would have to be "converted" to shares).
You can recreate your shares and use a backup job to restore the content of the first folder on the USB disk to the first share on the volume, when finished, change to second, etc.
About the "new volume" button, I don't recall if on RAIDiator 4.2, you can create a second volume on unused capacity of already used disk. I don't think this is possible on OS6, but not sure on RAIDiator 4.2. It rings a bell. That said, I do think the button only appears if there is unused capacity (if it's possible) or unused drive.
zigdapig
May 20, 2017Aspirant
Hi, thanks for your reply.
I just went ahead and inserted the disks, and the volume size was indeed not expanded automatically.
But you were correct : the "new volume" button appeared...
So I just made additional volumes, and now I'm happy again.
- jak0lantashMay 20, 2017Mentor
Thanks for confirming. So Flex-RAID is indeed very different on RAIDiator 4.2 and ReadyNAS OS6.
- StephenBMay 22, 2017Guru - Experienced User
Yes.
