pb360
Mar 03, 2014Aspirant
Replacement Disk
Hi, Need to replace a disk on my ReadyNAS Duo - what are the best disks for it? Disks are currently Seagate ST3500321CS 465 GB , 29 C / 84 F , Write-cache ON but I want to upgrade the one I repl...
Mar 03, 2014Guru - Experienced User
Personally I'd go with 2 TB, since the prices are quite similar (at least in the US).
The western digital wd20efrx is a good choice, though you might need to run a utility to change the head parking threshold.
The 1TB model is the wd10efrx.
Both are intended for NAS, and have longer warranties then consumer desktop drives (3 years instead of 1).
