pb360
Mar 03, 2014Aspirant
Replacement Disk
Hi, Need to replace a disk on my ReadyNAS Duo - what are the best disks for it? Disks are currently Seagate ST3500321CS 465 GB , 29 C / 84 F , Write-cache ON but I want to upgrade the one I repl...
vandermerwe
Mar 03, 2014Master
Yes you can, although if you are using xraid you will not see any increase in volume capacity until you replace the second drive.
If you're using each disk as a separate volume, you'd need of course to copy the data to another location, replace the disk then copy the data back.
