Phantome46
Dec 14, 2012Aspirant
Replacement drive help?
I have a ready nas NV+ and was experiencing issues with a dead drive. The 1TB drive was showing full and i only had 420gb of material on it. I have replaced the drive - and its still showing 0/931G...
Dec 14, 2012Guru - Experienced User
Ok. So putting in a new disk didn't change anything because (1) the disks are mirrored (2) when you replace one disk, the NAS simply resyncs (restores the mirror from the other drive).
(1) Have you checked each share in the share listing, to see how much information is in them?
(2) Do you have the recycle bin enabled for any of the share? Look at "share listing", select "CIFS" for each share, and scroll down until you see the recycle bin checkbox
(3) Have you ever backed up your Mac with Time Machine to the Duo?
