Phantome46
Dec 14, 2012Aspirant
Replacement drive help?
I have a ready nas NV+ and was experiencing issues with a dead drive. The 1TB drive was showing full and i only had 420gb of material on it. I have replaced the drive - and its still showing 0/931G...
Dec 14, 2012Guru - Experienced User
Trying again:you have two mirrored disks. So "that disk" is a meaningless concept. You have one data volume (C) which is both disks together. If either disk fails, all your data continues to be available.
Phantome46 wrote: i have checked all of the share listings and only have approx 420ish GB in them on that disk.
Absolutely not. The mirror is not visible to you. If you have 420GB in Media, and another 420 GB in backup, then that is ~840GB all together.
Phantome46 wrote: so my assumption is media is my drive with 1TB capacity and then backup is the mirror with the same capacity. thats why i can see the same on both?
You might want to empty them.
Phantome46 wrote: I have checked and do have recycle bin enabled on the CIFS shares for both media and also backup shares.
