Phantome46
Dec 14, 2012Aspirant
Replacement drive help?
I have a ready nas NV+ and was experiencing issues with a dead drive. The 1TB drive was showing full and i only had 420gb of material on it. I have replaced the drive - and its still showing 0/931G...
Dec 16, 2012Guru - Experienced User
Did you set up any backup jobs when you installed the NAS? Or maybe press the backup button? It wouldn't do this replication on its own. As I said, the mirroring is invisible to you.
Try adding one file to media (a small one, since you don't have much space), and then look in backup to see if it shows up immediately. If it is not there, then wait a day, and then look again.
Also try deleting one file in backup, and see if it comes back. (You might as well check to see if it disappears in media as well). Copy the file to your pc first, just for safety.
