Phantome46
Dec 14, 2012Aspirant
Replacement drive help?
I have a ready nas NV+ and was experiencing issues with a dead drive. The 1TB drive was showing full and i only had 420gb of material on it. I have replaced the drive - and its still showing 0/931G...
Phantome46
Dec 18, 2012Aspirant
I have been running a couple of tests as you suggested above.
I have copied some files onto the media share and then looked at backup and so far it has not shown up?
I have also deleted some files from the backup share and they have not deleted from the first media share?
I think one of my original settings was i scheduled a backup task to create a backup of media each day - which i believe wrote the info to the backup share - thus creating a copy. and then the hidden mirrors you spoke about then created a copy of both of these shares?
do you think this is accurate?
If this is the case I believe I should delete the backup share completely from front view. But will this remove automatically the extra hidden backup which i don't see freeing up lots more space on my drive?
