Phantome46
Dec 14, 2012Aspirant
Replacement drive help?
I have a ready nas NV+ and was experiencing issues with a dead drive. The 1TB drive was showing full and i only had 420gb of material on it. I have replaced the drive - and its still showing 0/931G...
Dec 18, 2012Guru - Experienced User
No. The mirror is always happening. Every time you change something (add a file, rename, delete, update,...) the change is made simultaneously to both disks. You never see the mirror, but if one drive fails you still see all your data.
Phantome46 wrote: Once i delete backup share does that also erase the mirror as well?
