kevinffff
Jun 28, 2021Aspirant
Replacement fan - RN516
My fan has started to become noisy, regardless of speed setting, where can I can a replacement from please?
Sandshark
Jun 28, 2021Sensei
Netgear does not sell parts. You'll have to look for a standard PWM fan with similar specs. Maybe somebody has already done this and has a suggected model. But what I wanted to point out is that the connector pin order is non-standard. See ReadyNas-pro-6-fan-stopped-working . I'm not sure why nobody suggested in the post that the pins simply be removed and re-inserted in the new order, which is usually pretty easy with a fan.
Once you have done the swap, you may need to tweek the minimum fan speed in the OS if it starts stalling out on you when going at low speed. Are you comfortable with the Linux command lione via SSH?
- kevinffffJul 05, 2021Aspirant
Yes, I can use Linux command line, I grew up with CP/M & DOS so just have to google the syntax for Linux!
- SandsharkJul 05, 2021Sensei
Unfortunately, I've not seen anyone chime in with a specific model as a replacement. Once you get one installed, then you'll need to see if it stalls out or needs a spe4ed boost to cool well enough. If it does, then those can be adjusted via SSH.
- kevinffffJul 06, 2021Aspirant
I have ordered this, will see how it goes:
CYRMZAY Compatible for NMB-MAT 4710KL-04W-B56 12cm 12025 120mm DC 12V 0.72A 4-wire PWM case cooling fan
