ramymounir's avatar
ramymounir
ReadyNas pro 6 fan stopped working
I am not technical at all i will try to explain as much as posssible
This device has been running for 3 years or so straight, it sound is quite, unless i reboot or something its sound becomes very loud not sure if it was the fan sound or something else, but i guess it was the fan then the sound gets back to normal when the system boots.
One day the device started shutting down by itself, when i turn it on it shuts down again so i check and the fan was not running and the device temp became so high i guess so it switches off..Screen Shot 2016-11-16 at 4.41.24 PM.png
I changed the fan, i couldnt find the same exact fan, but i bought a similar one from amazon, and when i replaced it, it still doesnt spin.
The system boots fine and stays for a while untill its too hot then turns off again.
any ideas?
  • bedlam1's avatar
    bedlam1
    Nov 19, 2016
    Still cannot see the photo's
    But here is something you can try, disconnect power from NAS first, it does involve cutting the extender cable leaving plenty of cable, so cut in the middle.
    Remove the insulation from each of the cut ends for about 10mm.
    Then join the cables by twisting them together as following:
    Connector to Power End                Fan End
                Black               to                    Blue
                Yellow             to                    Black
                Green             to                    Yellow
                Blue                to                    Green
    Insulate the joins with insulating tape, with some more around all 4 for added strength
    Connect connector to board, reconnect power, boot and see what happens
    No guarantee this will work, but you have nothing to lose, at your own risk of course
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello ramymounir,
    Is this ReadyNAS Pro 6 or ReadyNAS 516?
    If ReadyNAS Pro 6 then it means you have loaded an OS6 firmware. Please check the discussion here if it helps as the user also replaced the fan.
    Welcome to the community!
    • ramymounir's avatar
      ramymounir
      IMG_3485.JPGIMG_3485.JPGthe model is different, the one i have is the RN51600-100 6 drive
      I dont see that metal case with the fan that was replaced in the other post. mine only has one fan which i tried to replace..
      I dont see the power supply in my model.. did i change the wrong fan? but if so why is it still not spining?
      • bedlam1's avatar
        bedlam1
        Prodigy
        You have a Readynas 516
        I did a bit of digging regarding the fan and found this snippet
        " Rewire fan connector, RN 516 does not use standard wiring for CPU or Case fan...
        Standard PWM Fan:
        1 - Black(GND), 2 - Yellow(12v), 3 - Green(tach), 4 - Blue(Control)
        RN 516 PWM Fan:
        1 - Blue, 2 - Black, 3 - Yellow, 4 - Green
        Maybe this is why your new fan does not work....? Maybe a bit of trial and error.....this will probably mean cutting the cables and reconnecting them somehow or preferably buying a few new spare 4 pin PWM Connectors.
        What manufacturer detail is on the old (original) fan - Manufacturer Name, Part Number etc.
ProSupport for Business
