SMPTUK
Oct 08, 2017Aspirant
Replacement Power Supply ReadyNAS Duo RND2000
Hi all I been checking but to date unable to locate somewhere to get a replacement power supply for my ReadyNas Duo 2000 V2. Seem to be plenty of non Netgear options, but im not sure these a...
Oct 09, 2017Guru - Experienced User
Are you certain you have a v2? The labels are confusing. V2s run 5.3.x firmware, v1s run 4.1.x.
There's a guide here you might want to check: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
SMPTUK
Oct 10, 2017Aspirant
Many thanks
That article confirms it is a V1 with the recessed power connection.
All very weird that it states V2 as a sticker !
Regards
- Marty_MOct 12, 2017NETGEAR Employee Retired
Hello SMPTUK,
The v2 refers to revision not the hardware version. To double check you could PM(Private Message) me the serial number of your NAS then I will try to check it on our system. Do not post serial here on the thread.
Marty_M
NETGEAR Community Team - Marty_MOct 16, 2017NETGEAR Employee Retired
Hello SMPTUK,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
