cabwav
Jun 27, 2016Tutor
Replacing disks on NVX with previously used 3Tb model fails
Hello I have a RNDX4210 NVX Business Edition running RAIDiator 4.2.27. Some time ago I replaced all four 3Tb disks (Seagate ST33000651AS) with 4Tb models (Seagate ST4000VN000). Because I plan to ...
- Jun 27, 2016
cabwav wrote:
Thank you for the quick reply! AFAIK a factory reset means that all data that was on the drives is lost, is that correct?
Yes
cabwav wrote:
is there any way to do a FR without losing the data?
No it isn't. It is perhaps possible to force the RAID array to mount, but there likely would be file system corruption.
Jun 27, 2016Guru - Experienced User
You need to do a factory reset.
You upgraded to 4 TB one disk at time, so the original 4x3TB array is no longer usable.
