cabwav's avatar
cabwav
Tutor
Jun 27, 2016
Replacing disks on NVX with previously used 3Tb model fails
Hello   I have a RNDX4210 NVX Business Edition running RAIDiator 4.2.27. Some time ago I replaced all four 3Tb disks (Seagate ST33000651AS) with 4Tb models (Seagate ST4000VN000). Because I plan to ...
  • StephenB's avatar
    Jun 27, 2016
    cabwav wrote:
    Thank you for the quick reply! AFAIK a factory reset means that all data that was on the drives is lost, is that correct?
    Yes
    cabwav wrote:
     is there any way to do a FR without losing the data?
    No it isn't.  It is perhaps possible to force the RAID array to mount, but there likely would be file system corruption.
ProSupport for Business
